Penners
- Suffolk, England
This is really just a rant, but I'm fizzing at a blatant example of waste that I've just come across.
We've had some trouble with the time-clock on our central heating system. I've finally narrowed this down to a tiny "hearing aid" type of battery on the circuit board, which keeps the clock going when the mains power is switched off, and then gets recharged when the power comes back on. After about 5 years of service, this battery won't hold a charge any more, and needs replacement.
Except that you can't replace it. Instead of being held in a little clip with two spring terminals, it is soldered into the circuit board.
I have even called the manufacturers, to ask whether I could buy a new battery and resolder it in myself, but I was told that they are unavailable individually (in other words, I could probably buy 10,000 without any problem but they don't want the hassle of selling just one).
So, instead of buying a little battery worth, perhaps, a couple of quid, I have to buy an entire new time-clock for £77. And all of the old time-clock - fully functioning LCD display, switchgear, PCB, electronic components and all - is just so much junk. It's a shocking waste, and just one tiny example of the kind of mentality that we have to overcome if we're going to have any chance at all of reducing our carbon emissions.
On the plus side, the heating is now working again, so when the cold weather comes the Penners carbon footprint can return to normal.
