Penners
- Suffolk, England
Flyfisher has made a number of sensible points about your asbestos roof. So long as it's not drilled, sawn or otherwise persuaded to turn into dust, it shouldn't be dangerous. Painting it with an oil paint would improve its safety.
But if you're firm about replacing it, firstly you should consider the dangers inherent in removing the sheets. This could create dust, and it's therefore sensible to call in specialists for the job.
As regards your choice of a replacement roof, once again I agree with FF - pantiles could end up with little or no pitch, due to their overlap cant. But why not try laying a few on top of the existing roof to see?
The minimum pitch for slates seems to vary according to the size of slate, the headlap, and various other factors. But a rule-of-thumb suggests that any slate roof pitched at less than 25 degrees should be generously headlapped and well provided with a second line of defence (ie: membrane), and it's probably unwise to attempt anything less than 20 degrees.
Unless your floor has a lot of bricks in consierably better condition than those that you've shown us, I have my doubts whether it's rescuable. But I hope I'm wrong. However, if you need to, you can find all kinds of pamments and/or brick paviors in most reclamation yards*, or go and see Bulmer Brick & Tile, in Bulmer, near Sudbury, who make new ones.
As Graham has said, that clay lump wall looks as though it's crying out for lime plastering. Whatever you do, don't get any gypsum or cement anywhere near it.
* Be sure to choose a yard that subscribes to the Salvo code.
