Flyfisher
- Norfolk, UK
Correct, as far as the lamp itself is concerned, but the transformer that converts 240volts to 12 volts will not be 100% efficient. This means that to supply the 12V bulb with 100W, more than 100W must be provided by the 240V circuit.Lime said:Do not confuse lower voltage with less power.
It is not the voltage you need to consider but the wattage (power).
A 12volt 100 watt lamp will consume the same amount of power as a 240volt 100 watt lamp.
