Lime
- East of England
The fact that the wall has been treated before complicates the issue but it does suggest long term problems.
Also the recent leak has compounded the problem too.
As you can see for yourself, injecting a DPC does not sort out damp problems particularly when the source of the damp is not known or erradicated. It does make it less easy to predict how or when the wall will dry out however.
If the solid floor is still damp or the subsoil is saturated for whatever reason it is likely that the wall will not dry out if the moisture in the wall is coming from that area.
I think you need to ensure that the water/damp is not coming in from above via the chimney.
You need to be sure that the bathroom is free from leaks. It only takes a tiny leak to cause a solid floor to be saturated if it has no means of drying out.
You need to allow time for the floor and wall to dry out.
For me the main concern is the kitchen floor and what the dampness can do/is doing to the wood.
You can improve the situation by increasing the underfloor ventilation on the kitchen side by adding to and/or increasing the size of the vents. Removing cobwebs, rubble and dust will improve air circulation too.
It needs to be dry/drying down there.
If the solid bathroom floor is causing the wall to be damp in some way the solution is not obvious. The composition, depth, dampproofing (if any) and foundation of the floor is unknown. The condition of the subsoil is unknown. The area of contact between the floor and wall under the solid floor is unknown.
Basically any method that removes direct contact between the walls and the solid floor will do the job but that is not easy to obtain for obvious reasons.
