Dampadoodle
Hi all,
Ok. We are at our wits' end. the following is our damp story and any help would be appreciated....
The property is a ground floor flat in a terraced road (1890?). We have had a 'damp' problem since purchasing the flat in Oct 2005, where we initially noticed a stain showing through the cavity wall between the kitchen and the bathroom (on the bathroom side). The bathroom has a concrete floor, kitchen is suspended (approx2ft - wooden floorboards)
We then looked behind the ground level units in the kitchen (against the party wall) and behind the fridge and saw extensive evidence of damp (staining and strong damp smell). After investigating the bathroom plumbing, we fixed a leak that was putting about 1/4 pint water under the bath every time the shower was used (and this water followed pipes down into the area under the kitchen floor). We also ensured that the airbricks for the whole property were cleaned and blockage free.
We hoped that this had solved the issue but the smell didn't seem to disappear and the staining continued as well. We are now needing to install a new kitchen and want to ensure that when we replaster the walls and install the units, there will be no more damp problems.
We've had quotes from damp companies (wielding damp meters) and also had people on the roof to check the state of the chimneys, with quotes for repointing work and re-flaunching the chimney.
A few weeks ago I took off some of the low level plaster next to the floorboards and it was quite 'mushy' but now its exposed it seems to have dried out a bit. So we are now unsure if we have other ingress of water from somewhere (mains? drains? chimney? water table?) or if the old water from the leak is still slowly drying out.
The property has an old slate course under the kitchen, concreted side return, and small decked garden area. The damp is not on the external walls. There is evidence of damp in our neighbours flat on the other side of the party wall (peeling paint) and in their bathroom. There is no damp in the flats above.
So a few questions
1) How long would it take for the moisture from the bonding to dry out? If at all?
2) Could the damp be caused by bad pointing/flaunching on the chimney stack? (we think that the 'damp' wall smells more after it rains and the stack is directly above the party wall)
3) If the damp is caused by a dodgy chimney stack, wouldn't the flat above be experiencing damp too? - I ask this because we had a roofer come round to give a quote for the stack and he reckons that its fine in its present state and needs no more work doing to it, and that it is not causing the damp or upstairs would have issues too.
4) What should we replaster the walls with? Should we use lime? or sand/cement/waterproofer as everyone who comes round seems to suggest? or dry-lining (plasterboard). As floor level units are going to be in front of the areas where damp can be seen, we dont really mind the look of it, just mind drying time (kitchen is arriving in a week to be fitted by a friend). We have solid wood worktop and really dont want to ruin this by putting it near drying plaster/render whatever(!) too early.
This is the damp (or drying stains from previous damp) behind the units against the internal party wall.
The following is the view under the previous photo (taken under the floorboards). The damp in the photo above is slightly to the left, above the brick 'pier' (the thing that looks like a wall on the left of this shot is actually a brick structure sticking directly out from the party wall - could this have been an old hearth?)
This is a shot of the corner of the brick pier. So the camera is in the same location as before just rotated about 20 degrees to the left.
Next is a shot looking past the brick pier, parallel to the party wall. So,the camera is in the same location as before, just rotated to the left by about 10 degrees.
Last two shots above ground again! beginning to hack off the old bonding.
In the last photo, I'm pointing to some black, very wet material, a bit like wet charcoal.
Okay. So. any ideas? any answers to the questions above?
If you need further info tobe able to helpthen let me know!!
Thanks in advance for your time and help.
Pete
So a few questions
Pete
