Hi all I've decided to take the risk and ask for some feedback on these walls, this is the first time I've worked with lime plaster (or plaster at all). It's a lime putty and sand mix, first coat on wood fibre boards. I found the tool I had for creating the key to be less than ideal but I didn't have anything else to hand at the time (I've only got in one direction on some walls as the teeth seemed too tight). Do people think I'm going to run into some major problems now with following coats?
Thanks for your thoughts.
