RebeccaV
- London Bridge, SE1
Hello. Does anyone have any advice about the most sympathetic method to remove external paint from old London Stock brickwork?
The front of my house is painted. There are multi-layers of paint and there is also patches of render on some damaged bricks.
The paint is cracking and bubbling all over but particularly at low-level. I believe it is trapping water within the bricks. Also plaster on corresponding internal walls is damp and crumbling off.
I have contacted various companies who use (i) Therma-tech, (ii) Doff and (iii) chemical softening methods to remove paint but am at a loss as to which would be most appropriate to use on old bricks. Are any likely to cause more damage than others?
Thank you so much! Rebecca
