Hi everyone.
We recently moved into an old stone cottage and discovered some woodworm. Most serious issues are in the basement, so we have been treating there with permethrin-based products. Also found a bit up in the ceiling/rafters (photos below), however, and wondering what to do. The main beam (top photo) is sweet chestnut so, I've heard, largely resistant to woodworm at its structural core. Our issue is we have a cat in the house, and so have been slow to treat with permethrin in the living space itself.
Also relevant here is that for last 10+ years, the house was only used as a summer holiday home. It was locked up and presumably very cold and damp in autumn/winter/spring. There were a couple of leaks in the roof (the woodworm problem overlaps with where the leaks were, for the most part), which we have been trying to fix up. We have now moved in for year-round living, and installed a wood stove, which we are using nightly and heating the space, alongside the oil heating. We also open windows and air the place out when we can. However, due to the old stone construction, our relative humidity is still high (usually above 70), fluctuating a lot with the weather.
Some specific questions:
1. If we were to treat with permethrin in the living space, how long do you think it would be until it was safe for the cat? We will be treating areas in the ceiling/roof where he won't be physically touching, though he will be in proximity.
2. What are the chances of us moving into the place year-round helping with this problem, without the need to use permethrin?
3. Is there anything else I can do to disrupt the life cycle of these beetles, without using toxic chemicals? A neighbour even suggested that painting with diesel is an old-school method of dealing with woodworm.
Thanks for any advice or suggestions!
