davide2023
- London, UK
Hi all,
I have started redocorating what it will be eventually my work-from-home office. My first task was to strip the wallpaper: I went with some light cross scoring using a utility knife and a wallpaper steamer, but I am not sure it was the right way.
Underneath I have found some lime plaster, which has cracks on various walls and sounds hollow when tapped in some area. So my questions are:
- should I be worried?
- did I create the issue?
- if I did create the issue, how should I tackle other rooms to avoid the same problem?
This room was probably last decorated around 35/40 years ago, as I have found some charming newspaper underneath the carpet from 1988
Let me know what you think, I have a LOT of this wallpaper in this property...
Some photos before the wallpaper was removed are here: https://www.periodproperty.co.uk/fo...s-on-a-wall-before-wallpaper-stripping.17752/
