Spoilt Victorian Child
- London
Hi - newbie on the forum looking for a general consensus as to 'the right thing to do' (and how to do it). I've just bought a victorian house, in which I want to keep/reinstate period features, but make it modern in terms of decor, and liveable - not a museum. My first focus is on the staircase......
When I viewed the place I noticed it had all the spindles taken out of the staircase and replaced with one long plank. It looks well 70s. I was hoping to remove the plank and reinstate the spindles, and had my fingers crossed that the boxed in newel posts were in ok condition.
But unboxing them last weekend revealed a double disaster.
The top of the newel posts have been sawn off, not just the egg or ball or whatever topping it would have had, but quite a chunk below that too. Also, to fit the 70s plank securely, the back of the post has been hacked into to make a chunky mortise & tenon joint. I figured both of these things could possibly be grafted back in if I found the right carpenter.
But then I noticed when looking for where the spindle 'holes' should be, the overhanging side-lip of every step had also been sawn off. I'm guessing there's an inch missing for each step (you can sort of see on the back of the newel post where the bottom step would have gone out to in the photo below. Sorry it's a bit dark).
I'm not sure if these overhangs are structurally important to the steps? I'm guessing not as the staircase hasn't fallen down in the last 40 years, but I'm no expert.
So my 2 big questions are:
Is there enought staircase left to even bother reinstating/repairing it? I love the shape of the newel post, it's got quite straight lines, not like the bulbous 'victorian' things you see in B&Q. And the fact it hasn't been painted is a bonus. But I'm guessing a patch-in job is gonna be hard to mask unless I do paint it. I'm not sure if even the handrail is the original, although it does look a close second to my untrained eye.
Is it better to get replica spindles made, or to try and find something similar but reclaimed? My neighbour still has his original spindles, so I can see exactly what shape the spindles should be. (Sadly the top's been sawn off his post also, so still not sure if it should be an egg or a ball or what).
Thanks!
Thanks!
