malcolm
& Clementine the cat
- Bedfordshire
My house used to be a pub so most of the wires were surface mounted. Many more ran above the false ceiling and ended up in a rats nest of electrics and fire alarm cables when I took the false ceiling down.
Electricians are 3 times more expensive than they were in the before times (I guess they don't really want to do fiddly jobs just now). Half of the house has already been rewired and I can do the other half by extending cables which turns out to be within the rules. For £10K If it takes me 3 months I'll be in profit but I've set aside a month. Thanks @Zebra for the advice and book loan. I'll bring them back shortly - work got busy for a couple of years but it's happening now and the books and my notes are very useful.
Floorboards are up. On one side of the house they've been notched to death on the top and the bottom which will weaken the joists. With the double height room and staircase there is only one secret path to the other side and there the services are running through holes drilled through the centre of the joists as they should.
I'm starting with the fire alarm system. It's a nice wired system to industrial spec on the ground floor and residential spec on the upper floors. The wires are fire resistant which makes a lot of sense as the only time the fire alarm needs to work is when the house is on fire. It's expensive wire but I saved some money on the dispenser.
After 4 days of going up and down the stairs I'm close to completing first fix fire alarm. A lot of the cable runs through the loft space and I want to be neat up there rather than filling the loft with cables. I've gone for trunking to keep the cables out of the rockwool insulation and where I can't I've screwed the cables to joist support beams so at least one side isn't completely insulated. The boards in the photo are temporary to make crawling around easier.
