Hi
My stone walled terraced house has a bowing front wall(mainly on one side as you look on) supposedly due to the fact that the original tiled roof was replaced with a heavier concrete one.
I have had a quote for £4300 to tie in the wall. However, in discussion with the builders they mentioned drilling through the outside render. My problem is that I do not wish this to happen as I eventually want to remove this render and would not want any visible holes.
Would anybody know of an alternative approach to containing bowing walls and any recommended builders in the Bristol/South Wales area?
