fernicarry
- Argyllshire
As title says any experience with these? Do they make any measurable difference? They've very thin compared to 'real' insulation so the effect must be small.
Wall construction here is solid stone with lath and plaster hung on wooden studs 'dooked' into the stone. There is a fair amount of air movement in the void between the plaster and the stone which is a good thing in terms of keeping the wall dry but is very draughty. Starting from a fairly low baseline thermal-wise.
I'm moving the radiators next to the window to free up some wall space in two rooms which of course puts them on an outside wall. Putting something, anything, between the radiator and the outside world has to be worth attempting.
Most products seem to be 3 or 4mm thick. There is one thats only 1mm thick. I've got skirting boards off of both walls so can reattach over the thickness of the lining. This will move the board forward relative to the window architrave leaving it almost flush with the front face of the architrave. One room has a cornice so the step at the base of the cornice will be reduced. I think I can live with these detail changes if I get some comfort improvement in return.
Also strikes me could be useful for coombed ceilings that don't get the benefit of loft insulation. Wouldn't work for these two rooms because of the detail where the window recess meets the coom but would in other rooms if and when I get around to decorating them.
Thanks.
Thanks.
