Rim latch query
Post Reply
Craig89
Rim latch query
Post by Craig89 » Thu 17th Mar, 2022 9:02 am
A straight forward one i hope, I'm about to order new rim latches for 10 doors in my house:
https://www.broughtons.com/store/produc ... -black-lh/
2 of the doors open outward, are the latches fitted on the outside of the door or on the inside, with the bolt reversed and some sort of catch cut into the door frame?
Thanks, Craig
Cubist
Re: Rim latch query
Post by Cubist » Thu 17th Mar, 2022 10:15 am
Hi Craig,
Outside would be the most simple and effective approach but may be visually unappealing. Its possible to fit the lock inside but that would require some significant surgery to the door casement to accommodate the bolt receiver/box.
Cheers,
Cubist
Feltwell
Re: Rim latch query
Post by Feltwell » Thu 17th Mar, 2022 7:18 pm
Hi Craig
I'd say outside - all the doors here with rim locks are inward opening, the one outward opening door (to the cellar, off the hallway) has a mortice lock - I'd say if you got doors opening onto a "posh" area like the hallway then they would have used a mortice lock.
Craig89
Re: Rim latch query
Post by Craig89 » Thu 17th Mar, 2022 9:46 pm
The 2 doors in question are, 1 off the upstairs landing to the attic and the other from the utility to under the stairs. So not exactly in posh areas. The better half thinks it would look odd to have them on the outside with all the others on the inside which I do understand. But the reality is I don't think they would normally be used on the inside of an outward opening door. Hmmmmm....first world problems
Craig89
Re: Rim latch query
Post by Craig89 » Fri 18th Mar, 2022 9:20 am
I think I have come to the conclusion that a rim latch on the inside would require too much butchery to the frame and just wouldnt be "correct". Also I don't think it would look right on the outside so am probably just going to go for a couple of small mortise latches.
Thanks for your thoughts
Craig
plasticpigeon
Re: Rim latch query
Post by plasticpigeon » Fri 18th Mar, 2022 10:37 am
Just for reference, I have one outwards opening door in my house that has the rim latch on the outside. Strange as the person inside could get locked in, but as you say any other way would be too much effort.
a twig
Re: Rim latch query
Post by a twig » Sun 20th Mar, 2022 6:04 pm
Depends who the person inside is - might have been a sensible precaution! :twisted: :twisted:
malcolm
Re: Rim latch query
Post by malcolm » Sun 20th Mar, 2022 8:05 pm
I'm sure there was a rim latch in my grandmother's house that was mounted on a wooden plinth to get it past the door jamb. That was probably an alteration from when the door was made to open the other way.
I wouldn't retain the locking function from the outside if you have children in the house. Too much fun to be had there.
CliffordPope
Re: Rim latch query
Post by CliffordPope » Tue 5th Apr, 2022 9:31 am
It's interesting that the advert distinguishes between left and right handed locks - presumably so that the catches can be uniformally above, or below if you prefer, the level of the latch, regardless of which side the door hinges on?
Our house has an original mixture - the locks are all the same, but the catches are up or down depending on which side the door hinges. I've never noticed that until reading this thread.
Craig89
Re: Rim latch query
Post by Craig89 » Tue 5th Apr, 2022 11:58 am
I have decided on some small mortise latches for the 2 outward opening doors, having chose them with the same backset as the rim latches so externally they will all look the same.
Yes broughtons do sell handed as opposed to just turning them through 180 degrees to fit either side. It just makes things a bit more uniform.
I have disabled all of the thumb locks with some bits of brass to stop their movement.
Feltwell
Re: Rim latch query
Post by Feltwell » Wed 6th Apr, 2022 1:56 pm
If you used the rim locks here on the "wrong" side, you'd be putting the key in upside down, which would be a bit odd. Plus often the keyhole is set a little lower than the spindle for the doorknob.
Post Reply
Who is online
Users browsing this forum: No registered users and 11 guests
