Househunter
Hello all.
My cellar --- or is it a basement? (I never know, but it seems to have been used for more than just storing food/wine.) --- is a trifle damp. (Hygrometer readings show a relative humidity of around 95%.) As ventilation would be rather awkward to introduce through the walls, I've hit upon the wheeze of opening up the flue in the smaller of the two fireplaces, and getting a wood-burning stove going down there, effectively using it as it would have been used originally. The HETAS chap looked it all over and said that provided the stove was rated around 5kW and no more, the existing ventilation would suffice --- the stove should draw air through the room from beneath the cellar door (which can always be left ajar, should more airflow be needed), sucking the damp air up the chimney and gradually drying out the walls. The thermal mass of the walls will also provide a great heat store to help warm the house, which was pretty chilly this winter and difficult to keep comfortable for long with just gas central heating.
It seems that the cellar's been damp for some years, and so the walls need attention: the pointing is crumbling away, and the lime wash is flaking off (there are filamentous growths on the surface in places --- I'd guess they're probably fungal hyphae, rather than plant roots). I plan therefore to scrub all of this off and clean the walls back to the stone, rake out the mortar joints, re-point them in lime, and then apply a fresh coat of lime wash. There is also lath and plaster on the ceiling which needs redoing.
And so to my question...
Is it better to put in the stove first and dry the cellar out before cleaning it down and doing the lime work, or is it better to do the cleaning and lime work while the cellar is still damp and then install the stove to dry it out? I remember reading somewhere that new lime work must not be dried out too rapidly.
Has anyone here had issues along these lines (i.e. a stove creating problems with new lime work)? Any input is much appreciated!
Thanks,
HH
Thanks,
HH
