When stripping out to re-board walls and ceiling we have discovered one end of a wooden lintel has completely disintegrated as a result of a water leak. The leak was repaired around ten years ago from what we can tell but obviously the damage wasn’t! Oddly we found newspapers from 2014 stuffed in by the lintel that are bone dry, so that’s something at least.
We’d like advice on how big a job/fix this needs to be - can it be “patched” in any way? Can we use treated timber rather than steel?
Kind of annoyed we even found it as no sign anything has really gone wrong. Although we suspect the studs in the lathe and plaster wall are taking load that they shouldn’t be, so if we’d knocked them out (no plans to) it could have been more of a disaster. Photos show damaged area and other side of same wall.
The room is on the back of the house and has a pitched roof and comes off the turn in the stairs - so is lower than the main bedrooms in the main section of the house.
