Hi there all,
I'm after some advice please. We've recently moved into a 1830's cottage in the Midlands and have found that the front room floor is a bit damp. We removed the cheap carpet to find a good quality underlay sat on what we believe are 1950's floor tiles - not good quality really. We removed them at the weekend and found they were sat on a sandy mortar mix which itself sits on a solid (but rough) concrete slab. The walls appear to have been chemically DPC'd as they have drill holes externally (plugged) and internally (found them after removing the skirting board).
After a bit of 'exploritary surgery' on the concrete floor, it appears very poor quality subfloor beneath.
Our concerns for putting a wooden floor in have been raised when we noticed the the sandy mortar is very damp. Now... can we put a DPM over the sandy layer and then float a battened floor (with insulation) over the DPM and then attach the floroboards to the battens?
How do I 'finish' the DPM to the DPC in the walls?
Could it be just condensation? We've recently opened up the chimney and installed a wood burner so will this help with drying out the room? Or will we allways have a damp problem and ruin quite expensive floorboards??
Thank you in advance (the flooring's arriving on Thursday!!)
Rob.
Rob.
