MetManMark
- Devon
All
We have decided to install 2 woodburners in our house. These will go in the living room and the room behind which will be our office. These rooms are at the gable end of the house. One of the chimneys protrudes from the house (ie external) the other is internal (ie the chimney is within the house).All of the installers have said that the chimney needs to be lined (which is fine). However, some have said that it needs to be insulated with a 'chim-wrap' (essentially a celotex style wrapper) or through the addition of vermiculite beads, others have said that no insulation is required. We will run the stoves pretty hot to make sure that all the gases exit the chimney and don't condense. The chimneys are about 9m high.
The chap that seemed most knowledgeable and works closely with woodwarm stoves (our preferred option) suggests the vermiculite - which we don't really like the idea of. I thought that filling the chimney with stuff isn't a good idea as it should be allowed to breathe. Thoughts?
Thanks in advance
Mark
Thanks in advance
Mark
