I’ve just had a HETAS installer come look at my woodburner-install job. The woodburner will sit on a raised hearth platform in a corner of the room, so it has a wall flanking either side. Both walls have been covered with cork insulation boards.
One of the cork-boarded walls was plastered over when he came to visit, but the other wall had the cork board still exposed, unplastered. He saw the cork and has decided that even AFTER it’s been plastered with 20mm of lime plaster it’s somehow going to burst into flames being 4-6 inches away from the nearest part of the woodburner. Because of that, he is going to insist that I tile behind the woodburner which is just another job I don’t need. How a layer of 5mm thick tile is supposed to stop the cork from bursting into flames but the 20mm of lime plaster WON’T is absolutely beyond me, but there ya go. Tradie logic I guess.
With all the wood wool and wood fibre boards people on this forum are installing along with plenty of wood burners in these old houses, I figure somebody must have dealt with this issue in the past? How did you get around the issue?
