88v8
- Glorious Gloucs
Chimney height....
Never had a woodburner, but having gone through our first winter with ye olde Yeoman Devon ( primary air only, and makes the cottage prodigiously dusty - here it is )
we are definitely hooked, and thoughts of oil heating have been abandoned.
In our other living room there is an inglenook with open fire & canopy, which already has a good register plate, and the fire opening is large enough for another woodburner. A Clearview Solution 400 would be the right size for the room, although with the large pane of glass it looks a little modern.
But.... to comply with the HETAS regs, the flue outlet has to be 6ft above the ridge. My ladder is in store, and peering from the ground I can see that probably we have no more than 5ft of freeboard above the thatch. The stack is stone, moulded, disproportionately posh for the cottage, and with an octagonal stone pot. I had thought to put the flue cowl on top of the pot, mounting it on a brass plate folded over to grip the top moulding of the pot.
The height.... the stack cannot be raised without destroying its history, and I am very disinclined to change the pot for a taller one, even supposing that it were permitted. This cannot be an unusual problem, although an installer I consulted was not forthcoming as to solutions.
What options are there? Do I add a narrowboat-style metal chimney & coolie-cap cowl to the pot?
http://www.limekilnchandlers.co.uk/index.php?act=viewProd&productId=470
or... might it be that the CO could 'persuade' Building Control to give a derogation? This would be the best option.
The existing Yeoman, there for 20+ years, exits quite happily through a chimney which I guess has less than 4ft of freeboard.
Any thoughts would be appreciated.
Ivor
Ivor
