yamin
- Alcester, Warwickshire
Mine is the message below regarding the sodden chimney breast that the builder thinks is because the flue needs back filling with vermiculite. Thanks again for the replies! Today I spoke to the man who fitted woodburning stove, and he had 2 cats to put among the pigeons
1. The twin skinned self contained flue that is using the chimney void is further contained within a pumice/anki liner that is already up there, the whole apparently surrounded by leca (?spelling? beads - much like vermiculite. This was already in the chimney, so previously lined.
2. He feels that the width of the chimney breast vs the width of the flue he utilised, indicates the presence of 2 original flues, with a divider, using the same chimney stack. This makes sense of course in a 2 floored house.
So, his suggestion was that the second, unused, flue, which presumably is NOT lined, is cold and therefore the condensed air leading to damp is coming from its ability to be warmed by the neighbouring used flue. This is complicated however by the fact that the other flue is lined (see above) and therefore should not be rising in temperature enough to affect the cold air in its neighbour!
This is all completely beyond me! I need a rub down with a damp edition of the radio times! In the meantime, I have given the builder the number of the fire man and asked that they talk, as hearing all this second hand through me, as you see here, is not terribly clear! Its so frustrating as I just don't know what solution to try. Backfill the empty flue? Put airbrick in at level of damp? (halfway DOWN breast of upstairs chimney breast). Whatever we do if its more than tuppence ha'penny it'll have to wait. Builder has suggested that I take a hammer and remove the sodden plaster, as its gypsum so not helping, and is so sodden it just won't dry now.
Any other comments welcome!
