plumbers mate
- Frozen north
My bathroom walls are wood panels - not cladding but wood on the main "studding"? of the lath and plaster wall - behind the wood is the back of the next room's plaster. The wood looks like the 1970's favourite pine cladding but is Victorian pine. The outside wall has the wood on the inside and behind that the structural double thick brickwork.
Presumably the victorian builder tried to pinch an inch or so of extra space?
However, I want an over bath shower - the present yucky green suite (avocado?) has to go and if I'm getting a new bath I'll get an over bath shower too .
So how do I waterproof the walls? I don't want to remove the wood but think it shold be covered with something and then tiled. This will preserve the integrity of the building even if it is hidden - the history will still be there. Most houses in the street have taken the wood off and replaced with plasterboard and tiles. Is there a lighter weight form of pre waterproofed "stuff" which I can fasten to the wood before tiling part of it?
The wood only goes down to what was the level of the (long since gone) cast iron bath which is how I know what the structure is.
Would I be better off taking the bullet firmly between my teeth and removing the wood on the two walls around the top and side of the bath?
Money is short and skills negligable.
