charlie-ia
- LANCASHIRE
our walls are rubble stone with lime. they are filled with odd bits of wood, some obviously old versions of rawlplugs, some seem just a bit random. all are usually very rotted. are we right removing them all as we find them? (we put a suitable stone in instead).
also, all the bedroom joists are resting on a strip of 2" x 1" wood (i will call it a wall plate unless there's a better word) this has also rotted. it runs most of the length of the house, but only down one wall. we have to replace this as the joists are nolonger properly supported.
it would be possible to put a thicker piece of wood in, maybe 3"X2" or more. would that be a good idea?
should we use wood preserver? i would have thought so, but i have read what you lot think about spraying for woodworm willy-nilly and wondered if wood preserver was just as pointless.
should we re-plaster over it using lime, or leave as much as possible exposed? it did have plaster over originally, but has rotted. the external wall is rendered with old cement, so i don't think it can breathe properly. perhaps just a thin layer of lime wash would be better?
