MatthewC
- Central/South England
Well, this week I have been starting to address one of the known issues of our house - the high probability of damp/rot/woodworm in the floor of the lounge. I am not at all surprised that I found it, and am now making plans to replace a number of joists and floorboards as a result. However, what has surprised me is the discovery of a long piece of wood at the base of what I thought was a brick wall.
View attachment 1 I had not removed all of the plaster but you can see it running half the length of the wall at floor level.
Now, I have already found some wood in the walls, where it seems to have been used to help attach skirting boards or other wooden items, like this (note a short piece of wood still present and scroll down to see the bit of wood which I removed).
This is, I suppose, fair enough given that masonry drills and plastic wall plugs were not in common use then, although the effect of damp is quite obvious. But the issue is with an internal brick wall, and the wood extends the entire 12 foot length of the wall. The bottom course of bricks overhangs the wood, and it was hidden by mortar which of course now falls off. I haven't looked at the other side of the wall yet as the stairs are there. In fact the wood itself doesn't seem as bad a condition as other places and there may actually be some good wood there, in which case I will treat it and leave well alone; if not, I'm scuppered!
My question is WHY oh WHY have they done this? There is no suggestion anywhere else of timber frame construction in this 1840 house, and simple partitions are lath and plaster.
Matthew
http://houseintheenchantedforest.blogspot.com
Matthew
