Morning all,
Long time visitor first time poster. Basically we've moved into an old house and it needs pretty much gutting. We've sorted the roof out so now onto the bedrooms, ive purchased 40mm wood fibre boards for the walls. When we have come to strip the walls we've found some of the walls have wood wool on them with lime plaster behind. Are we ok to screw the wood fibre ontop of the wood wool into the wall?
Hopefully so, because it will save us stripping replastering etc them walls. I can't see it being an issue, just want to check.
Also we have sloping ceiling in one corner of one room where we are thinking of pir boards between joist and wood wool over the top for plastering. If this is a good idea, whats the best method to seal the pir insulation between the wood joists?
A
A
		 . Anything else suitable to use?
		 (I really, really want that 'Tongue in Cheek' Smiley
