malcolm
& Clementine the cat
- Bedfordshire
I'm going for a change of use for a disused pub in a conservation area (which is like being listed on the outside). We've got some lovely very big 1920s leaded bay windows that I want to preserve.
As in previous topics change of use means building control is going to require we upgrade thermal performance (as we want to), conservation officer is going to want to keep the lovely windows (as we do). I don't fancy ruining the inside with ugly aluminium secondary glazing or even magnetic stuff but do want decent thermal performance. There is likely to be a trade off in insulation with building control as I don't want to make the 17c wood frame rot any more than it has already and will resist wall insulation. Can put as much as they like in the roof but very good windows might help negotiations.
We've got a good window frame thickness to work with and the windows are fixed and not opening. I'm tempted to fix single or even double glazed units (possibly thin ones) in the frame to act as primary windows behind the existing but am worried about condensation between those and the existing leaded windows.
Would old and poorly maintained leaded windows offer enough ventilation to keep the cavity dry or will I need to add some trickle ventilation from the outside? And how to do it nicely? The question is prompted by a load of research and a desire to plan ahead - I wasn't going to contact building regs until the planning application is done with.
