dalivar
- Flintshire, N Wales
Since I now realise that nearly all jobs lead on to other jobs, we're now considering replacing the 4 windows at the front of our house.
We started decorating our spare bedroom and have found that we need to patch up the lime plaster and also replace the inside sill (its poor-quality ply and also rotten from previous leaks).
My first question is whether it actually makes sense to replace the window before putting lots of work into finishing the room? I think it does, since the window will need to be recessed further into the wall, at the moment it is almost flush with the external wall.
And the second question is about double-glazed sashes... I know we want timber and I know we want to be warm! Does anyone have experience of double-glazed sash windows? The little research I've done so far suggests they don't last so well because of the weight of glass, one particular company would only fit single glazing in a sash window for this reason. I'm not willing to choose single glazing so should we look at casement instead?
The house is an extended end terace, half stone and half rendered on the extension which I also worry will make it harder to choose which colour would look best on the two backgrounds!
Thanks for any input!
Amy
Amy
