A
Anonymous
Guest
I thought I had fixed this problem but obviously not.
We have 4 big dormer windows all of which are a bit knackered. They have plastic windows which gives you some idea of how well made they are.
Three of them are showing no signs of leaking yet, but one is letting in water.
They are a bit unusual in that they arent flat roofed but the roof is on a very slight pitch (about 3 or 4 degrees at a guess)
These flatish roofs are coverd in artificial slates, and I think that they have roofing felt under the tiles.
The one that leaks is the most exposed and what I think happens is that wind drives the rain up under the tiles until it drips down inside.
The edge of the felt (which looks like thick plastic sheet) sticks out over the gutter. I had thought that the wind was driving the water up the underside of this so I hung out the window and crimped on lead weights to bend it down to help it drip into the gutter but this hasnt worked...
Any ideas?
I am pretty much resigned to having to strip all this#####off and re-roof but with what? The other dormers will still be tiled so it would be nice if we could keep the tiles somehow...
George
Any ideas?
George
