A
Anonymous
Guest
Hi, we've currently got an open fire with a cast iron fire surround. I'm keen to put a woodburner in it's place but believe that when I clear the fireplace out the dimensions won't allow for the woodburner we've been given to fit with sufficient clearance.
My question is really around how easy is it to increase the dimensions of the fireplace. I imagine that I would need to put a new lintel in to span the proposed dimensions but I am unsure how to do this safely. what level of support is needed and how do you provide it? Can I just remove the bricks and slot the lintel in place quickly ( this sounds bad). Having put the new lintel in place I would hope to remove the old brick sides of the fireplace to make it wider. My intention is to leave about a 10 inch wide pillar of brick at either side of the new fireplace to support the chimney stack.
Does this sound feasible? any advice gratefully recieved.
