American white oak floorboards £3 per m. It was stored flat inside the house for months (cough - years actually - cough) before use.robgil said:What kind of oak did you use?
I used kiln dried, but I did leave it in the house for a month before using it.robgil said:Thanks Stuart, did you use air dried or kiln dried Oak?
I can get quarter sawn for a little more but I think through and through might be more traditional?
Rob, is this an internal door? If so, then I don't think T'n'T will cause you many problems. But if it's an external door, I would definitely use quarter-sawn if you can afford it.robgil said:I can get quarter sawn for a little more but I think through and through might be more traditional?
robgil said:Is there any best way to store air dried?
robgil said:Cheers Biff, and finallywhat would happen if I just bought air dried and made the door straight away? It should be OK shouldn't it?
steveb said:boards are about a foot wide and 3/4 inch thick and of an indeterminate wood - does this sound like a realistic use for these and is it a possible DIY job with time and care (presumably I'd need to tool up with a router and a T&G or biscuit type cutter) or should I really be getting a time served carpenter to knock them up?
biffvernon said:Remember, before electricity folk did woodwork without electricity. It wasn't very long ago.
