A
Anonymous
Guest
Why is it that things you wish had been done properly (by previous owners) on your home rarely were, yet things you want to gid rid off are constructed as robustly as battleships?
Today is removal of concrete raft which was poured on to block off the chimney from the room opening when the central heating boiler was installed, leaving only a small hole for the flue pipe.
It's taking a very long time to remove, even with a hired hammer drill thingy. Why? One thick layer of concrete poured in onto wooden planks which were removed when the concrete set, (the chimney breast must have had a hole put into it for this) then cast iron grids, probably from the old range,, placed on that, as the filling in a sandwhich before another thick layer of concrete was poured. Try drilling through that lot!
Grrrrrr!!!!!
Why not a simple, easy to remove register plate, sealed around the edges?
Broken through now (a great deal of soot to remove too) but it's taken all afternoon.
Just needed a rant really.
Grrrrrr!!!!!
