Hello, and thank you for accepting me as a member.
I live in a semi-detached house, built in 1905. The front wall is sandstone, the other external walls are brick, which has been rendered and painted. The kitchen extends out at the back of the house, is original to the house, and seems to have a solid floor. The floor is covered with laminate which I haven't lifted yet.
The house is built on a gentle slope, so at the front the floor level is about 50cm about the ground, with the ground sloping away from the house. At the back, the floor level is about 10cm about the outside ground level, which is slabbed. There is a slabbed path along the side of the house, and the strip next to the house is gravel. The kitchen and attached conservatory floors are about 10 cm above the outside ground level, as a low wall has been build to keep the higher ground in a border, with a gravel path about 50cm wide around the conservatory. The ground level is lower here, as closer to the house slabs have been laid.
In the main part of the house, the floors (original joists and board, mostly) is suspended about an earth floor. A couple of months ago, an electrician had to go under the floor in the living room, and he came back up covered in white powdery mould, and decided he didn't want to go back down there until I found out what it was, and if he needed to take any precautions. Anyway, he did all the work he could do above the floor, and still hasn't invoiced me for that!
I wasn't sure who to get to find out what this white substance was - looked like white floury crumble mixture (as in apple crumble). So, I asked the estate agent who dealt with the sale when I bought this place last March. They recommended a surveyor on the basis that he didn't charge for an inspection - I took this to mean he'd likely try to sell me something to make the visit worth his while - and I arranged a visit.
I still don't know what the white stuff is, but the surveyor has advised that there is wet rot on the wood at the front and rear wall, as well as under the shower, which may well be leaking. This news wasn't welcome, but really any great surprise. I've already had to replace joist ends and floor boards at the front door, and the shower although new-ish, hasn't been very well done.
However, he then told me that all the floorboards would need to come up (in the hall, front room, shower room, and back living room) so he could put down plastic (?) sheeting which would then be covered in concrete. This, he said, is because the wooden joists etc are constantly sitting in a damp atmosphere and will all rot if nothing is done. He also said that having no damp proof course is a problem, as well as the bare earth under the floor.
Anyway, that was on Thursday, and he's going to send me a quote detailing the work he recommends.
Now, I do need to fix the wet rot, and based on other issues I have with the plumbing, I can quite accept that work will need to be done to the shower. However, having done a bit of reading, and looking at the house, I think the other problems are due simply to there being inadequate ventilation under the floor. There is one metal grille on the front wall, which is clear and lets air in under the floor. I'm pretty sure I remember seeing a similar grille or air brick when the floorboards were replaced at the front door, but the doorsteps are poured concrete, so that source of ventilation is blocked off.
At the rear of the house, I suspect there is no ventilation from the kitchen and the terracotta air brick in the living room wall is above the level of the floor, and although clear is then blocked off by wallpapered plywood.
So it looks to me that I need to improve the sub-floor ventilation, and not put down sheeting and concrete. At the back of the house I'll need to remove the slabs and lower the ground level. What will I do then to ensure that space doesn't simply fill up with rainwater?
Also how easy is it to insert new air bricks or ventilation grilles, and who would do that, and do it properly?
All advice, questions and thoughts welcomed. Thank you!
