I don't knwo if I should be worried and planning a lintel replacement or not !
The front part of the house was built c1600 ish. and is built of riverstone (granite mostly) and lime mortar.
The lintels I am worried about are over the front door. I can only see a little of them on the inside of the front door (there is another 15" of wall to the front of the house). The outside of the house has been rendered and painted at some point, so nothing to see there. I estimate that there are 3 intels (if they are all wooden all the way through and of the same size as the ones I can see). I can see about a 2"wide section of the first lintel and it has worm holes all over it, the second lintel behind it I can just see and appear to have beetle holes too, the third lintel I am just assuming exists, but I have not come accross a single stone lintel in theis place yet, so I doubt I'll be that lucky !
Is there any objective way of assesing if I need to replce them. If I have to expose them any more I'll have to strip the ceiling down from under them (I have had the floorboard up upstairs, can't see anything from there).
What is the best way to proceed ?
