vicky whitworth
- East Devon
Hello, please could I ask for some advice on a couple of things:
Firstly, when should I rake out mortar joints for re-pointing an external rubble stone wall? The wall is mostly lime pointed but has sandex over the top of it. I have been leaving the santex to weather/peel off for a few years but now want to re-point in lime in the summer. Prior to this I will need to rake out the old joints and I am thinking about starting this now. For two reasons: I want to be ready in good time so that I can start the re-pointing as soon as the frosts are over, and also because the walls are horrendously damp with moisture trapped behind the sandex. If I get the sandex off the joints now I thought it might help to get it drying out. But am I being too premature, and the wet weather will just drive in more moisture faster than it can dry off?
Secondly what would you use to make a hearth in an old fireplace? There's nothing of the original hearth left. We have opened the old fireplace. It has a brick arch and is quite wide. I think it would have had a range in it and/or been an open fire. We plan to put a woodburner in it. The floor in front of the hearth is slate flags. I wanted something to contrast with this so it is clear what is hearth and what isn't. What would you go for?
Any advice gratefully received. Vicky
