The middle room in our late 19C house has a suspended wood floor that's about an inch lower than the hall floor. This floor was chipboard and obviously a replacement; we know that the previous owners actually lowered the floor by about an inch to 'try and stop the damp'. One of the jobs we've decided to do was to lift up the chipboard and raise the joists so it's level coming out of the hall.
The joists are supported on three timber bearers that are sited directly onto the ground; they have rotted in a couple of places and there is a little white fungal growth at the point the timber is in contact with dampish earth and some growth on the ground:
The joiners were initially very concerned by the mould and there was lots of talk of dry rot. I am of the opinion that it could be, but most of the timbers are in pretty good nick and not rotten at all - only at the point they touch wet earth. After much discussion and research on here, the plan is to take the joists out, clean the mould and rubbish from the earth floor (which includes lots of scraps of old wet timber) and refit the joists at the correct height by hanging them off joist hangers that are attached to the walls, rather than supported by timber bearers that are sat directly on the floor.
The floor is dampish but not completely sodden; we found that the main airbrick that provides ventilation under the floor had been almost completely bricked up from the inside, so we are going to open that up to help dry things out.
Does this seem an appropriate approach? Is it advisable to spray a fungicide down there too?
