Could you please remind me what sort of sand I should be using in the mix to point brickwork with lime?
To make things simple, I’m looking to buy my sand in bags from the builder’s merchant. I realise that building sand is a no no (too clumpy) but should I be using plasterers sand which the builders merchants consider to be a sharp sand or should I be using the altogether coarser concreting sand? Secondly, do you use the same type of sand for both brick pointing and brick building? And I should perhaps go on to ask what type of sand should be used for plastering/rendering with lime?
Many thanks
Mike
Many thanks
Mike
