L1zzy
- North Dorset
Hi Folks - I have spent the last 3 weeks stripping 5 layers of paint off all the treads, risers and bannisters of my cottage staircase using Klingstrip. The reason for doing this is that previously the stairs were carpeted and being of varying heights and widths the stairs were tricky to negotiate so by revealing them one can see where on is going more easily.
The stairs are Pine probably victorian in places and 1970's in other places (cottage is 18thC but has sadly been gutted and 'revamped' at some stage in the past). Wood was originally painted in a thick brown varnish which I've left on in some places as I rather like the signs of wear between these areas on the outer edge of each tread against the base wood colour in the centre of each tread . In places due to the Kilngstrip action and the soaking with water to wash it off after 2-3 hours followed by Vinegar and water to neutralise the wood is rather woolley .Though now dried out it can be sanded smooth easily.
My question is what do I do now? Re apply a thick brown varnish over them or Holkham Linseed or beeswax or what - and if you think varnish is a good idea any suggestions on a brown stain and/or varnish, Some of the treads have slight splits to the outer rim so I'm keen to apply something that will support the wood.
Bif with all your knowledge of wood I hope yoou'll have thoughts but all most welcome.
