JLK
- Kendal, Cumbria
Hello forum - would welcome your views on the below, and any recommendations for lime render / plasterer / damp specialists in Cumbria in particular.
My third (top) floor, 19th century (exact build date unknown) flat has both a penetrating damp and a condensation issue on an external wall. The condensation I am dealing with (including by installing an extractor fan which has never been in place as this is a kitchen / living room). The damp is a bit tricker. That external wall has a concrete render (I know - it was there when I bought the flat, I didn't know any better at the time) which is cracked, and is gypsum plaster on the inside. From lots of reading on here it seems to me that the wall (a) can't breathe on the outside, and the concrete render is letting water in but not back out again, and (b) can't breathe on the inside either because of the gypsum.
In an ideal world (as well as addressing the condensation issue) I would take off the concrete render and replace with lime in the Spring, and remove the gypsum plaster on the inside and replace with lime, so the whole wall is breathable. However, the height of the outside wall means lots of scaffolding / possible expense, and while I'm getting quotes I don't know if I have enough money right now to replace the render (which is obviously the best thing to do). Any views on the following?
PS - I've had a type c damp proof course recommended on the basis that it's 'breathable', but am obviously v wary of going down that route.
PPS - I'd rather not post photos, thanks very much for understanding, and I know this means I'll get less detailed advice.
- If I do replace the external concrete render with lime, I assume I also need to replace the internal gypsum plaster with lime so everything breathes. Is that right, or can I get away with gypsum inside and lime outside?
- If I don't have the ability to replace the external concrete render with lime this year (and I know it should be done at some point), is it worth replacing the internal gypsum with lime plaster so the wall can still breathe on one side? Not perfect, but better than nothing?
- Any other solutions you've seen?
