Norton Fletcher
New Member
Hi,
Some drains in the back yard need digging up & replacing.. regarding the water channel along the back wall highlighted in orange.. which is cracked & knackered along it's length..
Do I:
1. Replace with an Aco into drain, keeping existing offset & slight slope from wall.
2. Replace with an Aco into drain, flush with the wall.
3. Replace with an evaporative strip covered in an open weave membrane and gravel i.e. get rid of the channel completely.
4. Leave it as it is until I've saved up enough to have the back yard repaved and do something then.
It's an 1896 Victorian, stone outer, cavity, inner brick behind, suspended timber floor.
To the left of the back door is the same with suspended floor on cast iron beams and keeping cellar below.
Don't want to waste precious funds on a new Aco if it isn't needed..
Thank you.
Do I:
Thank you.
