What’s the best material to use for backfilling drilled holes through 9” solid brick and lime mortar walls?. I’m looking to have a couple of outside taps installed at different locations which will be connected to the internal cold water main hence the need to drill two seperate holes through the wall. The ideal material would seem to be the expanding foam which can completely surround the pipe and fill the entire 9” depth of the hole but I’m sure you will have other suggestions. I will also be looking in the future to install a drainage pipe through the wall for sink/ washing machine etc. so a much larger bore than the two outside taps. I don’t think the foam would be suitable in that instance?
