David Angel
I have a small, clay tiled, pitched roofed outbuilding and the felt underneath is shot. Some of the tiles have also seen better days.
1) I see forum recommendations of a breathable felt called 'Dupont Tyvek'. Can someone confirm that the website below has the correct stuff? It appears that it is called Tyvek Supro.
http://www.breathermembranes.co.uk/epages/Store2.sf/?ObjectPath=/Shops/Store2.Shop1509/Products/un102
2) To re-roof, is it as simple as :
- Remove all tiles (and remove lime motor holding top tiles)
- Remove the horizontal battons
- Take the old felt up
- Put the new felt down (and leave overhang at the bottom for guttering)
- Replace with new battons
- Replace tiles + remorter the top ones back in with lime
3) I need to replace some of the tiles (approx 50%). They look like a fairly standard affair curvy clay tile as seen on old properties. Should I first look for reclaimed ones? Or is it best to buy new hand made ones? Can someone point me in the right direction online for new ones?
Thank you in advance for any advice you can give.
