111mart111
Hello everyone,
Thanks for taking time reading my 1st post.
I have moved into a 1880 Victorian House, and have just managed to sort through enough things to get into the loft.
The good news is that the loft has NO lining on the underside of the slates meaning ventilation is really good (you can see the cobwebs swing to and fro in the breeze!). However, I suspect a leak maybe the cause for the following:
Do any readers have any suggestions on what these spores could be? The wood is really solid and the spores can just dust off, but I am worried that they may be Dry Rot.
The following pic, suggest staining by a leak in the roof, but it is bone dry to the touch, so it could be historical. Indeed, as I took these pictures it was belting down but I could not see any evidence of water ingress:
Another example of the spores. Could it be salt from the slates leeching down to the timbers? A lot of cobwebs and almost like the insulation material I layed down a few months ago. I have a wood treatment guarantee from the previous vendor (a developer), could these spores / staining be a result of the treatment (there seems to be a lot of dead bugs up there ...)
I took a cheapy 'damp detector' and pressed into the wood / bricks. Unsurprising it went off the scale on both ... I know these devices aren't too reliable, but still.
Whilst we are in the loft, any idea why these joist holes (see left and right of the picture) aren't being used? A change in the beam layout?
Finally, do you think this is the original pointing from 1880? I'm interested in looking what lime plaster looks like:
Either way, I am getting a roofer to look over the roof as there is clear daylight coming some areas (but not near where the above pics were taken, althoug I know water can travel ...) Hopefully he can patch up the slates and along with the good ventilation make these spores go away!
Many thanks for reading the post. Regards Maarten.
