smurf355
- ledgu10mr16
So having discovered loads of old underground drains, pipes, voids, pits and a huge underground brick built tank (I think it was in years gone by collecting rainwater from the roof guttering) anywhere any digging or excavation needed to take place at my house, yesterday we found the icing on the cake. An actual well, just under the concrete path leading to my side door. Just where we need to excavate to run a new foul waste drain and very close to where a new footing is supposed to be dug. The guy operating the pneumatic breaker was lucky not to have fallen to his death. The well was covered with what looks like a few slabs of 1" thick slate and then a 3" concrete pour on top. We had no idea it was there, it's only 1.5m from the wall of the house. It's 20 metres deep, 1.1m diameter.
As he was breaking up the path, the point of the breaker just dropped down with no resistance - as they had found load of other old clay pipes and pits, he assumed he had gone into a pipe or an old drainage inspection chamber or something. After carefully removing the rubble, they noticed the big slate slabs. Fortunately the tip of the breaker had gone into the little gap between two of the slate slabs. If he had been a few inches either side and driven the breaker tip into the centre of one of the slabs, it undoubtedly would have broken clean in the middle and everything would have fallen down the 20m to the bottom of the well, including him!
A very close call. Now I have this thing to deal with! It's dry at the bottom, which is very surprising given the depth.... where did the water table go?
I don't know yet where we stand with digging footings and drainage so close to this. Anybody dealt with a well right beside their house before?
