I’m still trying to get my head around the terminology “well graded sand” when referring to lime mixes. Is this available from most builders merchants and what exactly is it? I think I read on this website that it comprises of various sized granules from 6mm down. I’ve recently done a few patch repairs to some outside rendered walls (19th century stucco) in one case using a 25 kg bag of ‘plastering sand’ and in another case using a 25 kg bag of ‘grit sand’ which I think is sometimes referred to as concreting sand. Both of these are readily available from the 3 or 4 builder’s merchants in my area but when you ask them the granular size of the sand, they tend to give you a puzzled look. The results with the plastering sand are not too bad, where as the results with the more textured grit sand is far too harsh and lumpy. Any further advice would be much appreciated.
