Nigel Watts
- London N7
Last weekend's storms resulted in water penetration through the roof in two parts of my house, both in areas reroofed within the last few years.
The house is an 1840 brick semi, four storeys high with a low pitched slate roof. The party wall carrying the chimney stacks rises above the roofline for the whole depth of the house, is rendered and capped.
A pint or two of water came through a small wire hole in the ceiling of a top floor bedroom adjacent to the party wall. When I went into the attic to see where it was coming from I noticed that water was running down the face of the brick party wall in a number of places.
I am rather mystified by this because only three or four years ago I had the roof recovered - new Welsh slate and new lead flashings at the junction with the party wall. Are the flashings faultly perhaps, or could the water be penetrating from the chimneys?
The other mystery is water penetration through the roof of my new lean-to extension. This has a continuous greenhouse-style rooflight the length of the lean-to. Above and below it the sloping roof is covered in lead. In stormy weather there is usually some water pentration in one section, at the upper edge of the rooflight. Could water be getting under the flashing and travelling uphill for a bit before getting in?
Any ideas?
Any ideas?
