In a similar fashion to Keithj, Keith b and others, I too appear to have rain water coming through a 9” brick wall, in my case into the loft space of a felted and slated ‘lean-to roof’.
The loft of this lean-to is about 10m long from end to end and at its highest point against the lean-to wall there is sufficient height within the loft to kneel upright.
My problem is the roof rafters which sit partially within the wall appear to be absorbing water from the wall during heavy rain fall. The top 2 or 3 feet of the rafters become completely saturated resulting in water dripping onto the loft insulation and in some cases running down to the eaves. You can imagine all the patches of brown water staining that have developed on the ceilings of the rooms below.
I had a professional roofer come round to look at the problem and having examined the roof from inside and out and checking all the lead flashing he could not see how the water was getting in. In his opinion, the roof, the lead flashing and the wall all appeared to be in perfect condition bar the water saturation of the rafters.
The other side of the wall is exposed to the elements but again, it is all in very good condition. There are 12 courses of brickwork above the highest part of the roof and these courses were re-built about three years ago using NHL 3.5 hydraulic lime.The rafters and roof were not disturbed during this refurb but the lead flashing was was reset into the wall. The top of the wall is all capped with those rounded off capping bricks (not sure of the technical term) and all the lime pointing is sound and solid.
Does anybody have any ideas on what the problem might be?
