Keithj
- Witnesham, Suffolk
We had rain worthy of old Noah this weekend. The wind was from the south west, and strong. Water was coming into the dining room and making healthy sized puddles on the floor.
We've paid lots of cash to a specialist builder to fix the problems with the house, so we're not best pleased that it's leaking. He's coming back tomorrow, and we will discuss with him the problem and solutions. But before going into the haggle, I'd appreciate the views of the assembled wise folks here.
The south gable wall is a bit of a "kludge" because the floor joists/beams were slightly too short to rest properly on the end beam. The previous beam was rotten, and the joists held up only "by art". The water ingress problem was serious.
This is the arrangement now:
The oak beam is new, as is most of the wall structure. There is an additional beam "inboard" of it to support the bedroom floor/dining room ceiling. Below that are the window frames. Above is lath and lime/chalk render on the outside, and plasterboard/skim on the inside. The gap is insulated with wool.
The lime render on the outside stops about half an inch inboard of the oak beam, so there is a small shelf on which water can collect.
I think water is collecting on this shelf, driven towards the wall by the wind, and then percolating under the render. There is a paper-thin gap where the render has dried/carbonated and the green oak has shrunk slightly.
When the rain was heavy, we had a stream (not drips) of water running from the beam, down the window frame, and onto the floor. I can't think of any other plausible reason for this.
My non-expert solution would be to get the lime renderers back to add a fillet to the render, taking it outboard of the oak beam, like this:
My theory is that the fillet will stop water collecting on the shelf and being driven into the house.
Is that a valid theory and the right solution to the problem?
Next question: there are similar "shelves" elsewhere around the house where lime render meets sole plates etc. Should they all have such fillets?
