Hi
I've posted previously two questions about my shower room renovation and the damp and rotten sole plate and posts that I am patching. As I explore more of the sole plate my latest discovery is that when I removed the old sink and pulled off the (damp) plaster board I actually found water droplets on the wall. The sink itself was on a thick piece of tiled plywood ( which was dry) and then attached to the wall. So I don't think that water came from the sink. But the dampness does seem to be !ocalised around (slightly below and to the left of) the waste water pipe. We have had a heavy downpour on Friday and raining saturday.
This area used to be a doorway in the past, and someone has built a new plinth wall around the door posts and put a new post in the middle. All three of which are rotten at their bases. I went round the other side and the exterior doesn't show any major problems - just the faintest of cracks around the waste pipe.
I think I have two options:
1. Re-route the waste pipe internally so that it joins onto the shower waste which exits from a similar hole about 3 feet away - this means I will have less external pipework and I can seal up the hole. But if that proves too awkward with the pipe run and stud wall for the shower enclosure; then
2. Alternatively I may reseal the pipe. I'd probably take the old one out put a new metric one in that matched the sink fittings etc.
So my question is - how should you install a waste pipe through a lime rendered wall (which has an outer skin of cement and paint)? I would have thought that the pipe would expand with heat and the wall will always resist that so you'd always get a break in the seal? My thoughts were:
A. Make the hole slightly larger and fit a slightly bigger pipe ( just a small section) like a sleeve for the waste pipe to go through. Then backfill around the sleeve with lime render and silicon seal or expanding foam between the two plastic pipes.
B. Some kind of flashing I.e. lead - not too sure how I would do that? Perhaps cut out a section of the wall surface and lay lead over the pipe and then render over the top of that.
C. Re-render around the pipe exit making a similar structure (but much smaller ) ) that you find over a window to shed water off the wall.
D. Just use silcon sealant around the pipe as it exits the wall.
What do you suggest? Thanks.
