Dean B
- Wiveliscombe, Somerset
Hi,
This is my first post on this great forum.
I live in the larger part of a house built 1650, with an 1800 major overhaul. My half of the house has all the cellars. I've been here 3 months, and during heavy rain (and once during a light but prolonged shower) the cellar floods to a depth of about 2 inches in a puddle about 2 metres across. The water seems to seep from the bottom of the front wall in two or three places (not continuous along the full width of the wall) running down into the lowest point of the floor. The walls are sandstone with rubble infill. The water doesn't seem to be rising up the wall more than an inch or so. Original flags abutt this sandstone wall. The sandstone in the bottom course is still stable despite this water ingress. The house lies on a hill, and the flooded area is the downhill side of the cellar. The cellar floor is about 7 feet below ground level on the dry side and 4 feet below ground level on the side where the water seeps in. A neighbour further downhill (on the other side of the road) has a cellar which she claims has never flooded.
I've done some research on the internet and initially put it down to increased water table levels flowing down the hill underground, and I was planning to build a sump in the floor to deal with these occasional rises. However the last 2 or 3 times the water has really smelled bad so I called Wessex Water last week and they sent a crew out. They checked all the drains around the house and the sewer in the road for blockages and it was all flowing freely (however the rain had stopped by the time they came). They tested the water in the cellar and confimed it was foul although it was not too strong and they suggested it could just be groundwater contaminated with decayed leaves rising up during heavy downpours.
After reading a few webpages on water tables, I think now that it cannot be groundwater as groundwater rising naturally should be fairly clean and it smells too bad to be anything other than sewer related. The chemical test done by the Wessex Water chap identified amonia contamination. I'm no expert on how sewers are constructed, but I had a good look when the water guys came out and I'm sure that there is only one system for rain and foul in the road. My guess now is that when it rains heavily the drains overflow and foul-contaminated water is discharged into the surrounding ground. My cellar wall is about 7 metres from the main drain in the road and the land between my house and the road is flat. The hill continues down from the otherside of the road.
There is no domestic drain in the vicinity of the cellar (my drain goes into next door's garden and joins the main about 15 metres down the road).
The guys from Wessex Water were looking for the obvious (a blockage) and when they couldn't find anything they left scratching their heads saying there was nothing else they could do. I obviously don't want contaminated water in my cellar (even if it were to be contained in a sump and pumped back out again).
Has anyone else encountered anything similar, and if so what was the cause and how was it resolved? Is my theory about the main drain overflowing plausible (there is no evidence above ground that it overflows)? If it is the main drain, is Wessex Water liable for rectification costs, even though the problem seems only to appear in my cellar?
Any help or advice will be gratefully received.
Cheers
Dean
Cheers
Dean
