Hello,
Rubble infill field stone walls, with suspended floors and underfloor ventilation.
I am insulating between the joists under the floor with kingspan.
I am insulating the between the wall studs with kingspan.
Is it OK to run floor kingspan up against the stone walls and then put a piece of DPC against wall and then spray foam the gap between the kingspan and wall to stop draughts up the wall?
Or should there be a gap between kinspan and the wall so that the wall also has access to ventilation?
